- Joined
- Dec 28, 2006
- Messages
- 383
- Points
- 172
Last week my sisters 1.9 jtd MW refused to start so she got the AA out to try to help. The technician said the fuel pump would be broke and seen as it was bank holiday there was no point in having the car recovered to a garage as it would just sit there all weekend.
Suspecting this to be rubbish as it seemed strange that the car hadn't had any problems the day before I went round to have a look.
Miracle upon miricale it fired up after a few turns of the key but ran like a pot dog at first. After it had cleared itself it had run fine for a week or so. We put it down to the diesel maybe freezing as it was extremely cold when it happened. Anyway the car ran fine for a week but its done it again and will not start again the weather is absolutely freezing. We had the car towed to our independant garage who have put it on their examiner and it was coming up with a couple of faults. 1 of them being crank position sensor! I have read many posts on this sensor and problems it can cause but none that I have read so far have said they were unable to get the car to start.
Basically what happens is you turn the car over and it barks as if it is going to start then just stops coming up with " engine fault" on display in the dash ( at which point you think No SH!T SHERLOCK)lol
The garage has checked to see if fuel if getting through and at the correct pressure which it is. But they aren't sure that it is the crank sensor either as they have spoken to a FIAT Technician and he has told them that the diagnostic computer will come up with those faults anyway when they wont start but it doesn't meen that thats the fault. They have suggested to them that it could be a faulty imobiliser. They have still a couple of tests to do but they say but wont be able to do them till late monday as they are extremely busy at the moment. I would appreciate any idea's on what it could be. Many of the symtoms suggest it is the crank position sensor but none of the posts on here are quite the same.
Any thoughts?
Any thoughts?
