Faults.
Faults.
Right it seems my car goes maybee 5 mins without the Engine Managent Light coming on (EOBD).
I got an Engine Diagnostic done by Audiowise in East Kilbride last saturday and they found 5 faults.
1) Random Multiple Cyclinder Misfire
2) Ignition Coil A Bank A Primrary circuit 1 fault (Hope that makes sence)
3) Ignition Coil B Bank B Secondary Circuit fault (again hope that makes sence)
4) Landa Sencor (o2 Sencor) faulty
5) Manufacturer Fault.
Basicalyl HELP!!!! Mark Ming HELP!!!!!!!!
Thank You
Andi
All seems to happens once the car has warmed up. Change the first lambda sensor.
P.S don't go second hand, last time i needed one, fluffy sells them at the best price and don't buy those universal crap from ebay, they don't last long.
Ming
See one thing you could try, am pretty sure the 2 lambda uses the same plug. The second lambda is practically useless and highly unlikly both be ****ed!
Try swapping the plugs between the 2 lambdas where it plugs into the ECU.
Ming
Andi_F said:
**** didny realise there were 2 Lambda's on the Sei :stunned:
Plus I thought the main part was a rounded shape or am i looking at somethin else????
Thing is rounded and is bolted in ur mani, one before the cat and one after the cat. I think the one before is the causing the problem.
Ming
Andi_F said:
Which bit?? thing is ther's 2 or 3 different Sensors on that link for the Sei!
When they read the ECU, when a faults comes back it doesn't mean that sensor is ****ed as they are all related. All the ECU records is ab-normal operations. Change the lambda sensor (the one before the cat) ...
Ming
gotta agree with ming here andi, unless you get the problem fixed, its a waste of time getting the light turned off!!
YcMing said:
Is no fooking point turning off the light. Get the parts changed before you get it reset. Last time am posting in this thread...
Ming
125.963% agree!!!!!
the light will just keep coming on until you sort the problem! (unless you take the bulb out) but it wont change the fact you still have a problem!
