imported_abyss113
Established member
- Joined
- Apr 17, 2006
- Messages
- 2,135
- Points
- 377
i have now replaced the stalk unit which had melted on the car and the wiring terminal that had melted but the problem is still here
when i press the brake pedal fuse number 13 blows (Fuse 13 is bottom row in middle) 10Amp
from the BOO running guide fuse 13 runs these
Instrument Panel Power + Key
10
13
Engine Oil Control Unit (TD105)
10
13
Direction Indicators
10
13
Brake Lights
10
13
High Level Brake Light
10
13
now ive had a thought that maybe a wire further back has melted connecting another to it but im unsure of this ill have to check all the cable right the way back
but another thing has started to happen as well
when i lock the doors with the alarm fob the rear lights flash all the bulbs at the same time but it used to be only the indicators that did this
thats about all i can think of at the moment
10
13
10
13
10
13
Brake Lights
10
13
10
13
