Technical  fault codes for 1997 Ulysse
I am after the fault codes for a 1997 2.1 ulysse especially the ABS. Does the site have downloads for this?
Many thanks,
Alan.
Hi.
You need to connect to the OBD port on the car. Once you get a code..you can then google it to find common issues
the Ulysse was a joint venture with PSA - peugeot / citroen,
and I believe you need their Lexia software - rather than FIAT / Alfa kit e tend to use..,
Charlie . Oxford
Hi Charlie,
Many thanks for that. I have just bought a code reader and will be having a go when it gets a bit warmer. Will I be able to download the Lexia codes via google?
Best regards,
Alan.
Hi Charlie,
Best regards,
Alan.
Hi Alan,:)
ok - the basics..;
a lot of cheap code readers just read the ENGINE ECU - for engine codes
for airbag . abs, lighting circuits, etc,
you need to communicate with the body computer..
all faults are stored with a designation number;
heres a list..;)
https://www.fiatforum.com/scudo/179...-meaning-any-codes-please-post-them-here.html
Charlie
