Technical  Fault code P0220
You have to remember though your engine inside will be chocked up its still best to remove the inlet manifold and physical clean it out
Sent from my iPhone using FIAT Forum
I am so sorry now that i didnt took a picture of the inlet manifold as last week i cleaned the butterfly valve and i was shocked the way it looks inside.Like a chimney that wasnt cleared in years.
Is it recommended to clean it before or after i use the forte cleaner?
Also,is it a difficult job?I am willing to try anything to be honest as i like working on my car,but i am a bit afraid of the engine.
I,ve changed cambelt,driveshafts ,springs,struts and loads of other stuff,but i was always afraid of the actual engine.Dont know why
Thanks for your help so far!
It's not the easiest of jobs but I'm sure you will sort it, the forte will work on the deep inside so I would put it in and drive as normal don't forget the new gaskets, after it will drive better, and block the egr off to help prevent it happening again
I have blocked the egr a week ago.Cleaning the inlet manifold its a job that I am looking forward to,but it might be only after 2 weeks.For this weekend I have planned to strip the air intake all the way and to change the gearbox mount.I will let you know how things are going.Thanks again for your help.
A friend used oven cleaner in he's manifold he said it made it very easy got to be worth a try ?
That's what's I was going to use.As I use it for cleaning the egr and it is amazing.I agree with your friend
