Right you will need...
if there is any additions you would like to make please PM me and i will update acordingly.
- Car with badges on
- Credit card or thin card of the same propotions.
- Warm water with a small amout of soap in
- Also a hairdryer can be used but not essencial
- Tcut and cloths
- If using the hairdryer gently heat over the badge.
- With the credit card push it behind the badge and press into the adhesive
- Continue doing this in a circular motion around the badge.
- Eventually the badge should come off easily.
- Soak the area with the water/soap mix and gently with the card ease as much of the adhesive off.
- Once most of the adhesive is off use the Tcut to treat any faded paint and it will also remove the rest of the adhesive with a little elbow grease.
