FAO skate2create - Removing Front Fiat Badge
C
carterado
Hi Dan,
Can you tell me how did you take off fiat badge on the front.
I want to take mine off but I dont know how its fixed there.
Any help is appreciated.
Enjoying every minute with it ...
Not skate2create but...
Theres a small bolt behind the grille. Open the bonnet and look behind the bonnet catch, dead centre of the grille. Get a socket on it and remove it.
Designed by Italians, Driven by Enthusiasts
£30 Pair of Rear Marea Door Handles For Sale in a Dark Metallic Blue
so if I remove that bolt, I will have hole in the mesh ???
The mesh stops at the badge. You'll have a big silver gap with a hole.
I see. Well, thanks for the info.
I thought that the mesh is complete there. Think I saw Dans Bravo without the badge.
Then I guess I might pain it black like Oz.
Have a look here....
It will be a pain in the ass to debadge it properly and one of two things will happen: -
1) You'll have a flappy grille as to mesh accross you'll nee to take out the centre mounting point for a flush fit;
2) You'll have flappy mesh as you cant mount the mesh flush without taking out the centre section.
Hence - a black badge. ;)
"Doctor said to give up Keee-Babs. I said 'No, no-no'" :)
Thats true OZ.
What do I need for painting. What paint did you use?
Halfords plastic primer and then Satin Black chap.
i brought a sencond had grill for a tenner,
rounded the center bit,
cut the bit in the middle where the badge was,
put new mesh on,
cut part of the bonnet away
and sprayed the bit that sat where the badge was black
that prob dont make any sense!lol
i know what i mean,will get some pics up soon when im better
S
5
767
sly si
S
J
966
jason
J
