F fiatbanger New member Joined Jul 7, 2007 Messages 4 Points 2 Sep 20, 2007 #1 Hi,the rad fan is staying on all the time and obviously flattening the battery on my daughters sei.Is it the rad switch?,thanks JIM
oilrag Member Joined Nov 2, 2006 Messages 557 Points 78 Sep 20, 2007 #2 Yes, You could, to convince yourself, try passing a current across it with the engine cold. Similarly if you pull the leads/plug off it, the fan should stop, engine cold. Welcome to the forum
OP OP F fiatbanger New member Joined Jul 7, 2007 Messages 4 Points 2 Sep 20, 2007 #3 Thanks ,engine cold,fan still on,i have taken plug off ,fan stops,shorted plug fan on..Jim
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,863 Location Lake District....Moist Sep 20, 2007 #4 Sounds like switch is fubared then. Cheers D
