- Joined
- Feb 21, 2021
- Messages
- 34
- Points
- 58
Dear all.
Owning since 2018 Panda Dynamic (early build, ZFA 169000000under 4000 frame no). When bought changed belt and water pump (INA kit fitted)
Fast forward to summer 2022. 24K miles (40K kms) and 4 years later, belt broke. Pump had been leaking but thought it was a hose. By luck the 188A4000 engine is fail-safe when it comes to cambelt breakage. Failing pump had been leaking onto belt and coolant weakened it.
New pump and kit fitted July 2022 (Gates brand). Started leaking last february (less than 6k miles and 7 months). The pump spindle was "eaten" by the seal (deeply scored)
Changed under warranty. SKF kit fitted. Started leaking last week (just lasted 1 month),
There is no pressurising in system. No HG problems. Plugs are ok (typical coffee colour).
My question is: SHould I get a genuine one from a Fiat dealer instead?
Anyone of you has suffered these repeated failures?
Any trusted water pump make to get?
A stroke of bad luck or just substandard parts manufactured under lockdown?
Or is the workshop doing something wrong? (I mean bleeding circuit badly and turning the pump with no lubrication from coolant)
Would have fitted by myself the 3rd time but as it's under warranty, it's their task to put things right.
Any input greatly appreciated as this breaks the record of substandard parts during my land rover ownership (blue box parts...you know...)
Best regards from sunny Spain
Robert
Robert
