Technical  Extra Money Light EML (engine management light)
Tynemouth
So on Sat morning after about half an hours running I had to stop, on start up the EML light came on and stayed on( car started and ran fine ) even after a bit more driving and a couple of restarts it still stayed on.
Had to leave the car about 3/4 hour, on starting, no light, and its stayed off since, would my cheap generic OBD2 reader read any stored codes?
Given the way it started and ran my guess would be Lambda, but for now fingers crossed!
1.2, 73k 09
Mine comes on when the oil is 1mm below the maximum on the dipstick gauge. It did it again at the weekend. A splash of oil top up and the light was gone again. But mine is a Twin Air and they are oil obsessed.
1.2, 73k 09
OBD is a STANDARD.. so IF :rolleyes: there is a stored ENGINE CODE.. it should be visible..
the generic readers will give varying meanings to the individual P____ code though:eek:
I looked at a punto the other day that had @12 stored engine codes.. apparently a VAG reader had found NONE.
I use this for NON-fiat vehicles;https://www.ebay.co.uk/itm/Vgate-Sc...369487?hash=item4ab7cee50f:g:8O4AAMXQNo5TbowK
Low oil level shouldn't cause any kind of light
We'll unless ofc it's below the minimum level
It shouldn't but it does. A Fiat tech who's a friend of my neighbour said the Twinairs rely on the oil for the multi air stuff so has to be topped up regularly. I've had the engine light on 5 or 6 times on that car and topping up the oil sorts it for a couple of months. It's never been anywhere near the minimum level. I keep a 1/2 litre bottle of it in the boot.
Complicated temperamental little sods are these 0.9 engines.
I agree, I have a fault code reader made by Bosch, a small blue handheld device, four-line LCD, powered off the OBD plug. I bought it for use with my other car and it did the job perfectly; but just for a laugh I tried it on our 500. Unplugged something from the top of the engine to create a deliberate fault and straightaway had a fault code and a useful translation - “Acceleration sensor”. So it is possible to solve mysteries with a cheap and simple fault code reader - especially if the Extra Money Light is on, as those are the types of faults the Bosch reader is designed for :) the one you have linked to looks a good bet too as it has a similar multi-line display to mine.
-Alex
