General  exhaust
General  exhaust
squirrelson76
Hi can someone give me some advice my exhaust sounds like it blowing when i ave taken it to ats the said it needs a part replacing it as a hole just below the cat but couldnt get it and said to goto a fiat dealers took it to the dealers and asked them bout it they said its fine the hole should be there is this true or should it have a cover on it
A hole in the exhaust :confused: no exhaust ive ever seen has had a hole thats ment to be in it,the emissions test wouldnt get done if you had a hole because the idle test would read high. (y)
Dont have a cat on mine but do they mean the clam shell around the cat ? if so it would rattle as its just a cover or is the cat a solid type that just looks like a tube?.
If its just a cover its a heat sheild and will be fine if you pull it off.
