Technical Exhaust diameter
arseofbox
Principality Retained :)
Midlands
Oldschool said:
Tom, tou think of performance exhaust on the 1108.
ID on the collector pipe of the standard Sporting should be 43mm.
2" = 50,8mm.;)
Possibly...but IIRC its an over estimation of the OD of the standard pipe!:eek:
GeX
Established member
Lytham St.Annes
Noo, its not 50.8. Thats the OD that Rolls Royce Silver Phantoms use.
IIRC its Centos use 32mm OD..
GeX
Established member
Lytham St.Annes
On the Cento I only looked at the systems from the fannymould back. ie. the tubular (instead of cast) part of the system was od 32mm, if that figure is the correct one. I know it was definately less than 48mm cos that was the smallest mandrel tooling i had access to at my old job.
