- Joined
- Jan 13, 2018
- Messages
- 160
- Points
- 54
Stuck at work.
Does anyone with access to e learn or drawings know the outside diameter of the 1.2L 8v exhaust pipe.
I got a new centre pipe and chopped the exhaust. Slit both pipes and shoved together.
I'm having trouble getting a gas tight seal and getting the back box aligned to stop any rattling as the joint is too tight.
I'm going to buy a coupler like the one below instead, but I need an outside diameter to buy the right one.
Exhaust Pipe Connector Steel Tube Clamp with Screws Adapter Sleeve Joint Coupler (40mmx44.5mm-90mm): Amazon.co.uk: Car & Motorbike
Thanks as always,
Thomas
Thanks as always,
Thomas
