I was trying "to talk" to my ECU using a ELM327 1.4 interface with the FiatECUScan software and very thung went ok until I try to connect to the ECU. The software gives me the U1601 - CAN network error.
See image.
What can I do to solve this?
Is there another software I can use?
Did I buy the correct interface?
Thx
Last week and it would only connect to the engine management, the rest of the modules failed. Looking at the info on the Fiat ECU Scan page I discovered that by destroying resistor R4 on the board this should fix things, and bugger me it did!
All works fine now with no problems, bit of a fiddle killing the resistor though as its so small but you can cut it with a stanely knife or small watchmakers screwdriver.
