K Krapo New member Joined Sep 26, 2018 Messages 4 Points 3 Sep 27, 2018 #1 Hi just got a panda and have got error code p1222 what does this mean it is a 2004 semi automatic. Any advice would be appreciated.
D DaveMcT Distinguished member Written a guide Joined Sep 14, 2009 Messages 19,492 Points 3,294 Sep 27, 2018 #2 Google is great https://www.fiatforum.com/tech-talk/266337-fiat-specific-ecu-eobd-obd-dtc-error-codes-list-full.html P1222=Circuito uscita comando trazione Google says that means Traction Command Output Circuit. The actuators are electro-hydraulic so sounds like an issue in there. You need a selespeed gearbox specialist. An Alfa Romeo specialist may be able to help but don't expect it to be low cost. Last edited: Sep 27, 2018
