M moynesyt5 New member Joined Mar 22, 2008 Messages 10 Points 4 Location Dartford Jan 4, 2010 #1 Hi All Can anyone please tell me where the plug is for the EOBD / OBD is location on my 2006 Croma? Thanks Dave
DoIDon'tI Member Joined Feb 17, 2008 Messages 470 Points 81 Jan 4, 2010 #2 It's behind the cubby hole on the dashboard where your right knee is. You have to remove a philips screw to get the cover off. HTH.
OP OP M moynesyt5 New member Joined Mar 22, 2008 Messages 10 Points 4 Location Dartford Jan 4, 2010 #3 Thanks for that. I did look there, but obviously not hard enough! Dave
s130 Moderator Staff member Parked in the garage Written a guide Uploaded a resource/download Written a review Joined Dec 5, 2006 Messages 6,583 Points 1,712 Location Wrexham, North Wales Jan 4, 2010 #4 Up to top RHS of fuse box. Partly hidden by the two large cables.
OP OP M moynesyt5 New member Joined Mar 22, 2008 Messages 10 Points 4 Location Dartford Jan 5, 2010 #5 The two thick cables 'hid' the plug when I first looked!
s130 Moderator Staff member Parked in the garage Written a guide Uploaded a resource/download Written a review Joined Dec 5, 2006 Messages 6,583 Points 1,712 Location Wrexham, North Wales Jan 5, 2010 #6 Pleased you found them. Can I ask what device / software you are planning to plug into/use on the Croma?
OP OP M moynesyt5 New member Joined Mar 22, 2008 Messages 10 Points 4 Location Dartford Jan 6, 2010 #7 I've bought a U581 reader, so hopefully this will work. All the reaqders / scanners say they work on Fiats etc, so I'll give it a try. I'll let you know how I get on.
I icom102 Member Joined Nov 7, 2017 Messages 82 Points 81 Aug 19, 2019 #8 Is there an EOBD/OBE port on a Croma CHT/IE ?
s130 Moderator Staff member Parked in the garage Written a guide Uploaded a resource/download Written a review Joined Dec 5, 2006 Messages 6,583 Points 1,712 Location Wrexham, North Wales Aug 20, 2019 #9 icom102 said: Is there an EOBD/OBE port on a Croma CHT/IE ? Click to expand... This is the old original version of the Croma 1992 and in does not have an EOBD socket. Connections to the Engine ECU and ABS system, etc. are via Fiat 3-Pin connector interface. MultiECUScan support the Croma 92 but only the Engine and ABS ECUs. You will also need the 3-Pin adapter cable.
g8rpi Moderator Staff member Parked in the garage Written a guide Uploaded a resource/download Joined Nov 11, 2013 Messages 4,643 Points 1,331 Location Cambridge Aug 20, 2019 #11 icom102 said: Thanks Click to expand... Note that you need the KL / VAG-Comm to USB interface (and 3 pin adaptor) for the 92 Croma. The newer ELM-327 interfaces won't work. Robert G8RPI.
