Hello! Sorry in advance for long post
My check engine light came on a while ago on my 2005 2.2 l petrol Croma.
The fault codes initially said random misfire (code P0300) and intermittently also running too rich (code P0172). On the latest check at the MOT, it only threw code P0300, random misfire. This triggered a MOT failure.
The idle is a bit, but not overly, rough. Only a bit sputtery. The RPM is fluctuating up and down slightly at idle. Sometimes, the car cuts out at idle or when driving very slowly. Then it starts right back up. At higher speeds, everything seems to be working fine, although sometimes when I use too high a gear, the engine seems to run less smoothly. The fuel economy might be a bit worse, although not according to the trip computer.
I replaced all spark plugs and noticed black sooty fouling on plug nr 4 (or whatever plug is closest to the coil pack connector). The other plugs looked fine.
I tried to look for vacuum leaks: The lines I could locate looked ok, I sprayed the intake manifold and all vacuum lines I could find with starting gas, but couldn´t notice any change in idle (but it´s hard to tell when the idle is a bit rough). I also sprayed soapy water over the intake manifold gasket but couldn´t notice any bubbling or rev change. I even blew cigar smoke (!) through the brake booster line into the intake manifold, but couldn´t see any smoke coming out. It probably escaped through the air filter as I didn´t block this passageway, maybe I should have (it was way to easy to blow smoke through the vacuum line, I suspect I need more pressure to work against if the smoke is gonna escape through small cracks). Anyway, vacuum leaks usually causes lean misfires right?
Now, in lieu of better ideas, I ordered a new coil pack. I tried to test the existing one with a multimeter but couldn´t get any ohm-readings anywhere. I tried this with the ignition pack both on and off (i.e., testing both the 9-pin connector of the ICM and the 4-pin connector of the coil pack).
I haven´t tried a compression test of cylinder no 4, maybe I should. I guess it could also be a leaky no 4 injector. I don´t know if either should have thrown a specific P0304 code.
It could also be a defect O2-sensor or MAF I guess, but no such fault codes.
I can´t really tell if the sooty plug number 4 is related to the misfire or not. I thought maybe a defect O2 sensor or vacuum leak should affect all spark plugs equally, and maybe it´s just the no 4 coil that is malfunctioning - hence the new coil pack.
Any other ideas, it would be most appreciated!
