Technical engine stops
mick goodall
my 2.8 jtd ducato motor stopes when slowing down and the brake pedel is pressed when letting up the throttle at the same time fault code p1555 shows on the scanner whyats the cure please
p1555 is overboost wastegate sticking is common enough in this age van especially motorhomes which stand for several months a year. Disconnect the wastegate actuator and check the wastegate for stiffness, if stiff apply penetrating oil and work the wastegate lever back and forward until it moves freely.
