I've got a hgt 155, starts and idles fine, when you put you foot on the accelerator gently it revs up fine but soon as you put the accelerator straight to the floor it sputters and misses! Coilpacks seem ok and spark plugs look good! Any ideas??
my old petrol Corsa did this when one of the fuel pump vanes disintigrated and took out most of its neighbours, i managed to clear the debris and get it working enough to get to and from work for a few days while my online order was processed.
long story short, have you checked fuel pressure/delivery?
agreed.worth trying the inline fuel filter 1st I suppose, cheap + easy,![]()
im possibly misunderstanding your wording/intention here, but, my fuel pump experience (and gut instinct, with regards to other vehicles) says that slowly revving up to high RPMs with no load, would not draw enough fuel to cause the symptoms mentioned by the OP.by the same token, building the revs slowly , but keeping the rev's up
( high FUEL Demand) should also cause the issue..??![]()
hey up charlie,
agreed.
with a sickly pump, i could also rev the engine to 6k when not moving (granted, it was only a 1.4L single point injection engine), but when accelerating, i had to feather the throttle to avoid spluttering and juddering up to speed.
regardless, keep us posted on progress and i hope you get it sorted Damien.
cheers
I've connected all th pipe work up and started the engine and still sputtering! So I disconnected the MAF and it revs fine sputtering gone. So need new MAF sensor. Thanks everyone for your help and replys![]()
good to hear from you again,
Charlie
