if yes to both then check the fan comes on, check you have coolant, check you have coolant not just water . also check the thermostat on the right side of the head is opening as should.
hi guys a checked the car and it started so we then cheched the fan and all the pipes and it turned out there was a air in the systeam so i flushed it out and put new collant in it and it runs like a dream.
