Technical Engine Oil?
Hi All,
Currently trying to find out what oil I need to buy for my Fiat Panda Cross TwinAir.
The manual in the car says to go for 0W-30 but online it seems to suggest 5W-40.
Which one would be best suited for a 0.9L Petrol TwinAir? Mines from 2019.
Thanks!
Hi All,
Thanks!
Hi
I found Opie oils had the best configurator for the twinairs I was buying for..
Different ages and grades.. they were the only company I saw with sensible options
ECP /europrats were hopeless..
And thats without the added issues of twinair specific specs
Even Halfords claimed great discounts..
Petronas..but not the correct specs
Why not ask Shop4parts..or Alfa and Yapps.. as they are Italian car specialists
Most FIAT dealers are multifranchise..and poorer for it :(
I use the Selenia Pure Energy Digitek 0W-30 as recommended by Fiat. Keep some spare as they like a drink of oil!
Mine has 'burned' none in 72k..
The 35k motor is pretty good too ;)
But yes .. oil consumption can get expensive if the Selenia isnt staying in long
So yes 0W-30 is definitely the way to go, I've purchased some Mobil Super 3000 which has done the job. Although the car is complaining about not having enough oil despite the dipstick reading max 😅 I'll try to sort this tomorrow, might just be an issue with the reading.
There’s no electronic oil level sensor… but there is an automatic message to ‘check oil level’ that just pops every X thousand miles even if the oil is full. Suspect that’s the message you’ve seen
Hi Herts, yes this was the message. Luckily now I've sorted it. Despite the dipstick reading 'max' it still wanted more oil, a very misleading message really but it's been disabled now finally.
My twin air done the same I was told 0w30 she didn’t like it i had to change to 5w40 for peace my wee car is about to turn 100.000 miles never used oil it’s 2013
I’ve just posted some questions about TwinAir engine oil in another thread and realised it’s in the miscellaneous non-vehicle specific forum (link below) so I’m posting here the questions I raised:
1. what is the description on the can that meets ALL of the required TA “specification” - is “0W-30 C2” sufficient?
(the Panda Owner Handbook states “SAE 0W-30 ACEA C2 API SN 9.55535-GS1 or MS.90048, F020.B12”
2. “resetting” the TA - what bad things happen if this isn’t done? (my local independent probably hasn’t done this on my recent service+oil change (listed as “0W-30 C2” on the itemised invoice)
Any help gratefully received - in either thread!
