Wasted Spark
Some of you may have seen my other post about a suspected DMF failure. Car is a 2016 TA 4x4 Cross. I'm busy slowly stripping the car down while I wait for new parts to sort the DMF and seeing as so much has to be disturbed, I'm really trying to also tick off a lot of while-you-are-in-there type jobs. Something that was immediately obvious as soon as I removed the sump guard is that I have a fairly significant engine oil leak. Lots of accumulation on the front of the sump but I can see that the front the engine is quite wet with oil right up the head. With the engine cover removed, there was some oil traces around the coil pack area at the back of the engine on the top but also some dripping off the underside of what I assume is the cam sensor or something relating the exhaust cam on the front right hand side of the engine.
I know the chain cover is a common failure point on these but I would assume that would culminate in oil mainly down that side of the engine. So my thoughts turn to the cam cover gasket but it doesn't quite tally with the oil around the coils. But perhaps that oil is a result of a little spill during filling and it's a red herring? It is right next to the filler neck.
Thoughts appreciated.
