I think I post this yesterday but I can't find It, anyway I am about to order a new spring for my engine aft mount, there are two types of springs, standard and reinforced, thinking about reinforced have you try It?
The gearbox support plate is part #9 in this sketch, and shows the relationship to the u-shaped holder for the two rubber supports.
If you can't find a used one, they are available new at http://www.fiatclassic.com/, search for part #5305, and at http://fiat500-fischer.de part #29100. It is a part common to the 500R and the 126. Good luck!
You know i just understand why original spring is so soft, two cylinder engine vibrate a lot. I would like to know more for this "126" plate you are refering
MAL_3609 by Peter Thompson, on FlickrI think that's what giordini must have whilst gordinir has the original type.An alternative arrangement for many 500s is to replace the rear engine support panel with a 500R panel as that used the later engine mount same as the 126.
I ordered it from van Der laan .holandFD Ricambi lists the same spring for both cars, but I have reason not to trust them 100%.
Where did you order El c. ?
I've now checked another supplier: different springs for the 500 and the 500R/126 (500R/126: fewer coils = stiffer)
https://webshop.fiat500126.com/engine-parts-und-gaskets/other-engine-parts/1/
Something about your description seems a little "off" to me...
If I push down on my engine, the car suspension goes down of course, but the engine mount spring also compresses, but not down to the stops.
The mount only has two rubber stops (doughnuts), not four.
I'm just wondering if a previous owner maybe lost the spacer tube that goes on the center bolt and piled extra rubber bushes instead (?).
Unless there are differently-arranged mounts I'm not aware of...
