aFiFi
hello my dear fiat friends
i had this issue for a while now
my engine is overheating
i replaced
the water pump
the inner thermostat -the hose not the green piece
and the fan thermostat -the little piece connected to fan motor plugs -except i did not installed the specific one for the car instead i installed some old but working one for another car .
my fans are working probably
except the fan speed 1 does not engage in a proper timing and that makes the car engine over heat and very lean ..
i temporarily manually connect the fan speed 1 rely from the fuse box by wiring it but the engine code turns on and i want a real fix for the problem .
does anyone know how to do it ,
thanks and best regards .
:slayer:
i replaced
the water pump
:slayer:
