Technical  Engine codes
David1967
Wrexham wales
Hi mt engine code is 198A3.000 will a 198A2.000 if I switch turbo and injectors over ?
Also the Alfa Romeo engine code are the the same inc Vauxhall trying to replace engine with more options thanks
Doblo 1.6 mulitjet 64 plate
Sadly this is all I can find, however when I wanted to do the cambelt on my 2010 1.6 Fiat Doblo (non DPF) I had to use the cambelt details from my AutoData which only goes up to 2012 but doesn't mention the Doblo1.6 but as you can see in the timing book details that engine is used in Punto,Idea and Bravo in both 198A2.000 and 198A3.000.
Out of interest the 1.6 Alfa is listed as 940A3.000 in one of my photos so not sure about compatibility.
The other photos are from my vans handbook and some list the stop start models as Euro4, but also 263A3.000 though that may be the vehicle and not the engine. Having said that the Auto Data lists it also under Engine Series.
