Technical  ELM 327 OBD2 CAN Fault Code Diagnostic Reader
viper357
Worthing, UK
Hi all
I have a 2001 Marea 1.6, I need to read the error codes on my car and was wondering if this will work? (I can't post links ) This is the item number on ebay 180585890117
My ABS and handbrake lights come on occasionally and I suspect a loose earth cable or possible faulty ABS unit, so I want to reset or just read the error codes so I can try and fix the car myself, thanks.
I have no idea if my car is OBD or OBDII, I notice under the steering wheel I have what looks like a 16 pin connector?
Thanks.
Thanks for the help. I have run the fiatecuscan software on my car (Fiat Marea 1.6) and I found the following error code:
C1121 - ABS/ESP SV Relay
Can someone tell me where this relay is located? Is it in the fuse box or inside the ABS unit?
Thanks.
