Hello all - this is my first post on this forum - I've been here a few times in the past as a guest to find answers to various technical troubles with my van. This is the first time I've needed to register and post.
I have an A-Class motorhome based on a Ducato chassis. I've had it since new in 2009. Being what it is I know that a lot of the wiring has been modified from standard. The van gets a lot of use in the summer but is mostly left standing for long periods outside of then.
About three weeks ago the central locking started locking/unlocking all on its own at random times - maybe ten times in one minute and intermittently once or twice an hour afterwards. No flashers happening which does when used with the fob. Did all the usual common-sense diagnostic things like moving the fob out of range, looking at the wiring for obvious shorts etc.
Then a few days ago I switched on the ignition, and the wipers and screenwash came on as well. Stopped when I switched off but came on again once I turned the key.
Then the problem disappeared the next day.
Today it took another turn - three times the exact same thing happened when I switched on - Right hand indicator comes on along with main beam for five seconds or so. Then wipers/water as before.
I hear two beeps from the engine compartment that were never there before when I turn the key.
Now it's stopped happening but expect it will return soon.
My question is about the type of problem this is likely to be - is it likely to be a wiring thing i.e. a short somewhere, a CAN bus thing or something else?
I'm wondering whether there is an underlying problem that is causing both issues? Typing this I can see that it is going to be a job for the auto electrician but would be curious about others' experience.
