FiatFleetFamily
Established member
On Saturday morning, being a sunny day I unlocked my Croma and opened the windows at the same time ( Holding unlocking button down for 2 secs ) and all 4 windows came down. Got in and could not start engine as battery indictor showing fault. Put a multimeter across battery and only had 9 volts.
After a trip the Motor Factors to buy a Battery ( Varta at £96 with 3 year gaurantee ) Listed under Opel/ Vauxhall Signum, as Fiat Croma not in book. Changed battery, bloody hell they are big!! thought I had bought the wrong one.
Once changed, put key in ignition, and the amber triangle with exclamation mark came on with 4 messages saying window safety system failure on each window. Windows close fine and open fine, but the anti pinch system does not on each window as I tested this with a long carrot instead of my index finger.
I have checked all the fuses..all ok. Is this systen failure just because the windows were down and open when battery changed or is this an examiner job or what else can I check???
