Technical  Electric mirrors Not working
gareth111278
Dazzed & Confused !
Near Barmouth N. Wales
Hi
My in-laws hav ejust bought a 2008 1.2 Auto Eleganza.
one little fault is the electric door mirrors, they just don't work at all.
I've not got the specifit handbook for the Eleganza, just the one for our 'active'.
I cant find a fuse listed in our book but i've checked all the fuses (both boxes) & fitted a fuse to every empty space.
I'm now thinking it might be the switch, i've had a look & cant find one.
does anyone know where i might get one, other than payinh ££££ at Fiat.
cheers
Gareth
Hi did you get this sorted I have the same problem on my 2015 cross diesel I have ordered a second hand switch waiting for it coming
It’s a very basic system. No body computer.
Just one fuse, couple of earths and a load of switches
Probably not worth checking anything except maybe the fuse until the new parts fitted as it’s quite likely to be the fault
Is the F49 fuse the one behind the glovebox in your diagram? so are you saying the fault will most probably be the fuse or the switch
cheers john
cheers john
If there’s no life it could be either
The fuse is to the right of the steering wheel on a right hand drive car
Behind a removable plastic panel the other connector in the photo I posted is the OBDII diagnostic connector
cheers john
Have tried the fuse with a different one still N/G so have ordered a switch with the panel
Hi I have tried with a test lamp screwdriver with the ignition on and put it on the switch harness there are quite a few pins but could not get any light on the test lamp don't know if the screwdriver was touching the pins, it lit up when checking the fuse
Good test lamp is fine
Give me a few minutes to pull up the diagrams and decide on the next step
Just posting here as I keep loosing the cable code as the colours are in Italian
Cable colourCode
BLACKN
WHITEB
LIGHT BLUEA
BROWNM
YELLOWG
REDR
GREENV
GREYH
PINKS
ORANGEC
PURPLEZ
BLUEL
NUT-BROWNW
I don't know will have to take off again and have a look only trouble here is it is pissing down and i don't have a garage so will look later when clear thanks for your help by the way
just been out the wires to the mirror switch are yellow-grey, blue-white, blue-green. brown grey, green grey, grey white.
Just noticed your car is a 2015
Completely different wiring to the pre 2012 which all seem to share the same ish except the 1.1 active
The fuse I quoted earlier will be wrong as that’s for the pre 2012
