madrat Member Joined Aug 15, 2007 Messages 551 Points 123 Location Leicestershire Aug 5, 2010 #1 What are the symptoms of EGR failure?
johnson550 Fiats since 1973 Parked in the garage Joined May 15, 2006 Messages 1,362 Points 336 Location North East Aug 6, 2010 #2 poor acceleration on lower end and rough idle is a couple, theres a lot in the Stilo section about EGR valves. Heres a guide how to clean it, its a Stilo 150 but its practically the same. https://www.fiatforum.com/stilo-guides/156040-1-9-multijet-150-egr-valve-removal-cleaning.html maybe you could do a guide for the Marea if you decide to clean it. Last edited: Aug 6, 2010
OP OP madrat Member Joined Aug 15, 2007 Messages 551 Points 123 Location Leicestershire Aug 6, 2010 #3 Hmm, it idles fine its just that to pull away you have to give it a lot of revs, sometimes it seams worse than others. Acceleration seams fine.
johnson550 Fiats since 1973 Parked in the garage Joined May 15, 2006 Messages 1,362 Points 336 Location North East Aug 6, 2010 #4 when was the last time it was serviced.
Ffoxy Telford's Own... Joined Apr 26, 2007 Messages 13,616 Points 2,161 Aug 6, 2010 #5 When my EGR failed I had no power below 2,100 RPM & lost around 4 - 5 MPG, then above 2,100 RPM all came back in a huge rush... not good on wet / icy roads. Initially I had no dash warnings but eventually it did throw up an engine management light.
OP OP madrat Member Joined Aug 15, 2007 Messages 551 Points 123 Location Leicestershire Aug 6, 2010 #6 It must just be me then, its not lost any power, was serviced about 4 months ago,
OP OP madrat Member Joined Aug 15, 2007 Messages 551 Points 123 Location Leicestershire Sep 20, 2010 #7 Sorted the problem, the exhaust front pipe had a crack in it, now it's been replaced it pulls away normally again
