hi again.
Forgive me as this is my very first fiat and im trying my best to learn everything.
I have a fiat marea weekend 1.6 elx auto 1999 v reg 65,000 and have many little bits and pieces im trying to find out about by looking through everything on this forum.
Ok on my previous cars it has been easy to identify if I have abs by either slamming on the brakes or looking at the hubs and looking for abs sensors or the rings.
This car seems to have abs but in ways it seems not to have it.
Under bonnet in the fuse box I have an abs fuse of 60 amps which says I have abs. I recently changed discs and pads and on the passenger side (left side) on the pads is the wear warning cable and also what seems to be an abs sensor going to the hub. On the drivers side there are no abs sensors going to the hub. Also what makes this even weirder is, I was changing some blown bulbs on the instrument cluster and noticed that the abs warning bulb and holder was missing and in its place was a pice of wire soldered across the 2 terminals and also another wire in another place soldered to the 2 terminals. sometimes when pressing the brake the pedal seems like the abs is kicking in but during the ice and snow I thought id test abs out and my wheels just lock up. Is it possible that the previous owners disconnected the abs, changed the hub to a non abs hub or could it be almost set up for abs. im quite confused.
Other problems im having is the auto gearbox clicking like I have a flat spot on the tyres but tyres are brand new and have been checked also drive shafts have ben checked.
Even though I don't need it yet the air con don't work. the compressor does not turn on. any ideas where the fuse is located for the magnetic clutch or where the high pressure switch is located. I reckon it either needs a top up or new switch or fuse has gone.
Other then these faults I love this car and will work on it until its excellent. Recent work done is a new cam kit and clicking and small whining started after the cam kit had been fitted. originally thought clicking was due to wavy discs but I put new ones on and it still clicks.
Thanks and apologies for the long winded post
