Technical  EGR fault codes
jav225566
Czech republic
Hi everyone,
Any idea what I should check next? These codes keep coming back and are constantly being logged in the ECU:
  • P0490 – Exhaust gas recirculation (EGR) system – circuit high (electrical fault output 2 DC motor EGR)
  • P0487 – Exhaust gas recirculation (EGR) system, throttle position control – circuit malfunction (EGR position derives positive DC motor, opening insufficient)
I have already cleaned the EGR valve and checked the control mechanism coil—everything seems to be functional. However, after clearing the faults, I only need to drive a few kilometers before they reappear.
Other symptoms include increased exhaust smoke, an unstable/surging idle, and possibly higher fuel consumption.
Thanks for any advice!
Model
1.6 multijet
Year
2012
Mileage
144000
Hi everyone,
Circuit high often means the wires are broken and not even connected. You need to check that the electrical circuit is working properly.
The connector is plugged in properly. However, I only tested the functionality on the bench. It didn't cross my mind that there could be an issue with the wiring itself.
I need to find out how to test the wiring harness.
