EGR 1248 16v Multijet Diesel.. fumes = leaks
Ok. This is a follow.up
For a longrunning problem with the 1.3 mj in a Grande Punto.
Car bought in fair condition.. no service history.
Used for local travel.. on an occasional basis (thankfull no DPF..)
9 MONTHS after purchase did a 2 hour m.way journey.. almost gassed ourselves...
Lots of fumes in cabin.
The car had had the occasional whiff.. but nothing too bad on short trips.
Thankfully I own an almost identicsl sister car.. so know when something is amiss.
Had the basic exhaust checked = fine
So had a grovel around underbonnet..
Access isnt great.. :(
So took photos at rear of motor..
Comparisons:
One shiny
One sooty
Time to investigate..!!
As you could probably see..
The clip wasnt on straight..
Hardly surprising.. as you can SEE Nothing :(
After several attempts of :
Remount clip.. take photo
It became obvious there was a problem :eek:
The steel tube had been crimped by the clamp (as designed)
But with the tube out of square.. oops
So of course now its too small in ots 'crimped ' form.. to actuall mount up properly.. :(
A temporary extender tube:
Coke can and jubilee clip
Made the car driveable.. but not right.
A scan of ePER scared me .
EGR €650 thats the pipe in question
BRIGHT IDEA.. the mating flange : stub
Is much simpler
STILL EXPENSIVE €65
So I will try and dismount the stub..
Swage out the tube..
And mate the 2 properly.. then bolt the stub back into the manifold
But the bolt heads are mangled..
So wont come off easily :(
Bit of a bodge but how about some Gun-Gum then try and find a pipe from a scrapyard.
A few turns of steel wire (thin MIG wire or even better stainless steel locking wire) in the Gun-Gum helps support it.
Robert G8RPI.
No worse a bodge than my coke can.. :eek:
Biggest issue here is access..or visibility.
Glad its in a gp .. not a panda
Hard to see in the pictures but the pipe is concertinered up on the damaged unclamped pipe, I’d be inclined to remove it and see if it can be stretched out again carefully
3 hour job apparently.. :eek:
Im going to use an expanding former to try and swage the end of that hose back to its original.. pre.crimped dimension.
Sounds easy.. but there it very little space for tools..@1cm
Unfortunately the hose appears to be an integral part of the EGR.. around £600
And all out of sight behind the motor :(
