Hi Peeps!
Right people, the looms are ready to install but I need some important advice.
The Punto 75 I ripped the engine out of had one of those stupid Immobiliser rings around the ignition barrel.
On the manual PIN #7 on the ECU is marked as nothing, however on ECU PIN 7 connects via a two pin waterproof plug, through the bulkhead, to a small black box. The plastic ring that does something clever with a red key plugs into it also.
As far as I understand, the engine will not start without that red key being next to the ring around the ignition barrel.
Does anyone know how clever this system is? Can I simply remove PIN 7 from the ECU and start the engine normally?
Is there anything else connected to that black box?
The good news is I have the entire loom and the red key and ring from the Punto.
Nick
Nick
