Technical 1992 Panda 1000 ecu wiring diag
bighomer46
Hello, I am looking at this car for a client, The engine ecu is 61602.047.01 IAW6F.SF, i can not find a immo box in the car.
The car has arrived with a second hand ign lock barrel and short harness we have adapted the wiring so we can turn it on, the starter works but we have no output from the ecu to the second relay, so the fuel pump does not run and have no twelve volt at the coils etc.
I need to know where the immo box should be, and a wiring diagram also if the ecu has been made immo off how would we know.
Any help would be great
All being standard there wouldn't be an immobiliser on this age of car unless something aftermarket has been fitted. Not even sure the ecu feeds the power to the pump tbh, it's a pretty basic system. There is an inertia cutoff with a reset switch in the LHS footwell (on a RHD car) if you haven't tried that yet.
Thanks for the reply,
This might be helpfull to others
http://www.primauto.net/
Then click on the Fiat Badge it will open a page with all fiat cars and ecu after you can go to a more detailed diagram.
I have two ecus with the vehicle,
One says seat marbella 903 carb eco. Allegedly this is the original Ecu
I am having doubts.
