numnut20003000
- Joined
- May 15, 2013
- Messages
- 5
- Points
- 1
ok here goes
I got a 02 blue punto 1.2 8v for my girlfriends 1st car as a non runner
ive been in the game i long time so i thought it would be a simple fix to the problem described in the advert the women told me water had got into the tank an the would not start the rac drained the tank and she put fresh fuel in ok
i noticed straight away there was no sound coming from the fuel pump so live to the pump car started drove home no problems no misfiring nothing a little slow but the exhaust was blowing a little
i got a new pump but still nothing unless a used a live wire
i plug in the code reader
and got a load of codes
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0230 Fuel Pump Primary Circuit Malfunction
P0304 Cylinder 4 Misfire Detected
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0460 Fuel Level Sensor Circuit Malfunction
after looking up all these codes up it all points to the ecu so when i went to look at the ecu it looked very new, eventho it looked new i still went and got another
so plugged it in an still the same problems and codes
most people say its a common thing but maybe not for me would someone be able to advise where i go for here apart from the scrap yard ?
