For those who took out their catalytic converters here is a dummy load to replace the secondary O2 sensor and fool ECU that the converter is working properly by supplying around 0.5 volts to ECU.
The idea is simple to make 0.5 volts from 12v supply with simple voltage divider. 1k resistor is there to fool ECU that heater circuit is working properly, the red wire from the 470 Ohm resistor goes to vehicle ground (chasis).
I just took a connector from the old sensor and soldered the resistors to the wires that went to the sensor. The result is shown on the graph. For finetuning the desired voltage you can change the 10k Ohm resistor.
