At the end of my recent thread "Earth strap issue" concerning my Ducato's failure to start promptly, @Communicator helpfully suggested that I consider the possibility that a failing injector could be the cause.
I eventually plucked up the courage - there is just so much I don't know about these things - to apply sufficient force to the corners of the plastic engine cover to (partially) remove it & was disturbed to find that the channel housing the injectors was awash (photo). The cause seems to be a loose seal between the top of the scuttle(?) & the windscreen above the engine and also water getting through the wiper boss.
I don't know if an injector is failing but I imagine the water could be dripping onto the injector connections. From the degree of rust evident around the base of the injectors this has been happening for some time &, if this is the cause of the poor starting performance, predates my acquisition of the vehicle 3 months ago. What now concerns me is that the injectors will be physically seized & not be replaceable without requiring considerable effort & expense.
I've contacted the dealer I bought it from but pending a response I'd be grateful to know if - assuming that this is not an uncommon problem - there's an engine bay water deflector that I could fit (as I have done at other 'weak' spots) that would at least divert ingressing water away from the rear of the engine block.
- Model
- Ducato x250 3L 160MJ
- Year
- 2009
- Mileage
- 50000
