I've been lurking for the last 18 months, but this is my first post, so before you delve in, I'll say, "Hi".
Vehicle: 2006 / FIAT Ducato 2.8JTD X244 / manual (A Class motorhome)
Problem: Intermittent starting failure
Action taken:
It had an MOT yesterday – passed with no advisories – then failed to start on their ramp! Selected 4th gear, mechanic pushed it a few cm and it started immediately. It’s a twin-axle and weighs 4500kg, so it’s not something we want to be attempting to push often. It’s booked to return to the garage for further investigation work, but I thought I’d ask the community for any pointers that I can pass on to the garage. The garage is not FIAT specific, but they do have a contract with a large motorhome seller for maintenance / MOT work.
Appreciate your time. Thanks.
- Most of the time the vehicle starts as normal, however, sometimes it does not
- A single click can be heard from the engine bay (sounds like it’s from the starter motor)
- Immobiliser light on the instrument panel goes out – as normal
- Can happen with either key
- When it does not start, selecting 4th gear and pushing the vehicle until resistance is felt, has then enabled it to start – this may be a wild coincidence I know
Action taken:
- New vehicle battery fitted
- Starter motor replaced twice (incorrectly thinking this was the problem)
- Earth straps tested on a handheld machine at the garage
- OBD scan shows no fault code
- Battery clamps replaced
- OEM immobiliser disconnected
- Aftermarket immobiliser disconnected
- Trawled many websites / forums, but unable to find same problem
- Model
- Ducato X244
- Year
- 2006
- Mileage
- 47500
