Technical ducato 5 speed issues i need help please
Dabloom
Hi all i really could do you with a bit of advice on my 2005 swb ducato 2 2.0 jtd 5speed.
Its started off by being difficult two move the gearlever side to side and a pain to get in to second gear. And now its kind of escalated.
ive changed the gear box oil with the correct type and volume nothing much on the drain plug no big chucks. and still no better.
changed the gearbox control cables due to rust on the cables i even lubed the new cables before fitting them. I've also changed the bush in the center of the nylon gear change block.
I've even stripped and cleaned and greased the the linkage and replaced the pad which goes to the selector on the gearbox where the cables attach and it all looks like its moving through its range.
Other than pulling the gearbox does anyone have any other ideas or advice would be apricated as im about to pull out what's left of hair and i need to get the van back on the road sorry for along first post.
Thank you for all of the info, and all the suggestions. i have cleaned and greased all the linkage as shown. I've also bleed the the clutch for what's its worth and the clutch pedal is slightly better and going through its full stroke. I can engage all the other gears easily its just second gear thats being a pain.
