Hi guys hoping you can help.....
New campervan , mileage now 2100mls.
I've monitored the last 4 regens using multiscan whilst driving no issues until today.......entered regen sequence (when dpf clogging was 100.5% as per other regens) when in 4th gear driving about 40mph on A road, after about 2 minutes into sequence ( dpf temp at 620 C ) I braked for slowing traffic and was on trailing throttle for about 10 seconds...changed down to 3rd applied throttle and nothing (no response at all) , depressed clutch tried to rev engine in neutral again no response it was idling at 1000rpm.......once stopped lifted clutch slowly and was able to move away from blind bend using torque of engine , moved slowly along the road trying throttle for about 1 minute then it responded and picked up as if nothing had happened.......during this time it remained in the regen sequence and after the throttle response was normal again it stayed in the regen sequence until it's 7 minutes was up before exiting the sequence as normal.
Any ideas??? Oh no error codes either.
Thanks for any help, Graham
