Technical Ducato 2017 - Fuel pump assembly in tank - mounting screw not fitting?
ltz
Sweden
Had a broken "nut" for mounting the fuel pump assembly on the top of the fuel tank. Seems like all the autodoc ones have too small threads to fit. close but not fitting. Anyone have had the same problem? i'm thinking if Im purchasing the wrong item or if there are more then one tank to fit which have the same size of pump assembly but other mounting nut.
For instance this one.
could it be someone put in another tank in this car?? which tanks would fit fairly easy in that case?
