digger8954
- Joined
- Jul 18, 2012
- Messages
- 13
- Points
- 55
Hello all,
I wonder if anyone can advise on the following problem.
Engine will start on the key with no issies from cold, will run for approx 10 to 15 mins then cuts out. All ignition lights on the dash are lit as if you are about to start the engine, just as if it would if you had stalled it.
Once it has cut out, it will not restart unless its left to stand for a while, sometimes a few hours, sometimes half an hour and then it will restart. If it restarts after only half an hour of standing then it may only run for a few seconds before cutting out again.
This appears to me to be an issue of something failing once warm, ie, a sensor etc.
I wonder has anyone had the same issue and sorted the problem.
I have read stories of the crank sensor going faulty and shutting things down but didnt want to start swapping things unless sure.
The ecu is not throwing any fault codes or abnormal lights on the dash.
Any help, greatly appreciated. Mark
