Hi
Cold engine starts good but cuts rpm as seen on the video
https://youtu.be/qNvgLzodNbQ
The spec fuel pressure is at the top, and the pressure is measured at the bottom.
After few minutes the engine stops and cannot be started (measured rail pressure is 200-300 bar when turning with a starter) , only after a few hours the engine starts as before.
replaced fuel filter, new spark plugs and camshaft position sensor under the fuel rail, but still the same.
I tried the injection and scv valve adaptation, but it is not finished due to the engine stopping during the adaptation. EGR valve is broken
Faults:
p1304- injector adaptation not finished
p1306- hpfp pump adaptation not finished
p0405- egr position fault
Faults:
