Technical Dualogic question
StevieG144
Hey all, I’m new to the forum and have a tech question
I just bought a 2013 Fiat 500 Gucci with the dialogic transmission,
It drives great and shifts through all the gears fine other than it won’t go back into N if I shift to it, obviously it does when I turn the car off and back on as it resets. Everything else is great.
I checked the fluid level and noticed they it is way higher than the max level line (I levelled the car up on stands, car was not running when I checked level)
Could this be why I won’t take the N and beep ?
Thanks in advance
Hi and welcome to the forum.
I can't comment on the oil level question but the car must be left in gear when the engine is turned off. Our Dualogic has been gone twelve months now but if I remember correctly the beep warning comes on if you switch off the engine while in N.
