tobygray123
Hi All,
Really hope someone can help.
2009 Fiat 500 Dualogic
We had a oil leak on the actuator which looks like it was coming from a failed seal. I replace these parts and the oil leak has stopped.
Transmission fluid has been topped up to the correct level.
But now the car will not get into the right gear. Whatever gear is selected (apart from neutral) it will indicate as being in 2nd. But when I check the wheels, the car is actually in reverse. Can anyone provide any advice that could help me sort it as I am now stuck and have run out of knowledge
I have done a video showing the issue if you have a couple mins to help me out. See below link:
https://www.dropbox.com/scl/fi/97jh...7-05.mov?rlkey=mejymmysledzxqhz286ynmbim&dl=0
Many Thanks
Toby
Many Thanks
Toby
