Technical Dual Mass Flywheel
Italian Job
Rome
About to do a clutch change and thinking about changing the DMF and installing a solid flywheel (Original Fiat).
Anybody have any thoughts or has anybody on here done it ???
500L 2014 0.9 Twinair
Changing clutch because the release bearing is starting to complain, and pedal is starting to be a bit stiff, so pressure plate on its way.
What would you say are the symptoms of the DMF playing up because every now and again I get a strange noise when lifting clutch and its not the release bearing.
Just want to do the job once, and the solid flywheel is a Fiat approved modification, they produce the solid flywheel in exchange for the DMF.
