All right, all the wrenching has been done.
I actually found the adjuster using the part number and found it locally for less than 30€ new. Seems that Toyota Yaris mk2 uses same adjusters or similar ones, anyways those fit and work as a glove.
The reason why the handbrake lever (the one shown in the pictures) was off the place was because of some back spring behind the plate popped out of place and didn't hold like it supposed to.
Everything is in place now, tested it for a few kilometres, everything seems fine, pedal is still bit stiff but it's matter of habit now I think.
I will update again after some driving and will see will I encounter the same problem
Thanks again for all of your help (especially to you Jack) and I hope this thread or post help someone who is in need of replacing rear brakes.
Stay safe, everyone.
Ps. And here is a bonus picture of the car and the bag from adjustersView attachment 209102View attachment 209103
Thanks JimboyGood work Jack, well done for sticking in there. Not wanting to but in & tell anyone what to do, but make good use of free time to get to know your braking system, even if everything is working well, you could take the drums off & give a good clean. Check things out & see how it works, I mean when you become experts, you can save a small fortune by servicing & changing your brakes. Keep lubricating those brake cables.Tip, if you have to change cables & they are inner & outer type, before fitting hang them up & pour oil down them, this takes a wee while but can extend the life a bit longer. Graphite spray works well I've found.
Spot on Jack, as they say it's only easy if you know the answer. What I like about this forum are the car owners who are not mechanics but know their way around a car & give advise in real time & what to expect & tips that help. Mechanics are very knowledgeable & give excellent information, but there are times actually getting the situation spelled out from a novice point of view works, if you know what I mean.![]()
