_pennyPunto
I buggered up...!
Back story...
A couple of years ago, a friend gave me their old mk2 that had been sitting for 3-5 years. They were never gonna use it again as they now always go for lease cars (lucky them
So when I took it over I was surprised it passed its MOT. Need a few minors things easily sorted.
The problem...
Then last weekend happen...
Changed front disc and pads on both sides... straight forward, then obvious next step is to fully bleed the system. Easy I thought, except I snapped my nipple clean off the rear drum (passengers side). Luckily no leaks from my over tightern.
The issue is this, after spending nearly an hour trying to remove the dam drum, a few love taps hear and there! I got nowhere! So I blindly ordered of eBay what is supposed to be the correct wheel cylinder to replace the broken one.
Yesterday I spent over 2 hours trying again to remove the bloody drum but I think that, as it has not been looked at for nearly 7 years (min), that the drum has an internal lip. Meaning the shoes are catching as the drum is not slipping off as I would expect. I did notice looking through the wheel nut holes that the tensioner is expanded quite a bit. Tried to wind it back but to no avail.
I know if I could slacken this off a bit it drum will come off.
Any suggestions?
I'm now at s complete loss.
Thanks in advance
Ps also not sure if this is an abs system or not.
Punto mk2, 188 block, 3door, dynamic 03 reg
Back story...
The problem...
Any suggestions?
Thanks in advance
