Technical Drivers side front window
digger58
Established member
Limerick
Anybody have a wiring diagram for a 2008 1.4, drivers window is erratic. I have cleaned the switch contacts but no joy. I have tried to see the fuses but that is near impossible, WTF designed this fiasco? Before I strip the door I'd like to check the wiring. Do the wires break in the loom to the door?Thanks.
If the windows erratic it's more likely to be the regulator. Does it bounce down when you try and wind it up?
No bouncing, just works sometimes and then other times not. Have taken switch apart and cleaned contacts. just want a wiring diagram if possible. Anybody had this problem ?
Bump!
Anybody else have this problem? The window works perfectly most of the time then just refuses to work other times. Any hope of a wiring diagram? Thanks
